Web Analytics
Geometry
Geometry is the branch of mathematics concerned with space, shape, size, distance, position, and relationships between figures. It is one of the oldest areas of mathematics, originating from practical problems involving surveying, construction, astronomy, and measurement. Classical Euclidean geometry studies fundamental objects such as points, lines, planes, angles, curves, surfaces, and solids, while concepts such as congruence, similarity, symmetry, and dimension provide ways to compare and classify geometric objects.
The foundations of geometry were developed systematically by the ancient Greeks, particularly through Euclid's Elements. Euclid organized geometry using definitions, axioms, theorems, and proofs, establishing the axiomatic method that remains central to mathematics. Important classical results include the Pythagorean theorem, $a^2+b^2=c^2$, relationships involving circles and triangles, and methods for calculating areas and volumes. Later mathematicians such as Archimedes developed sophisticated approaches to areas, volumes, curves, and $\pi$.
From the 17th century onward, geometry became increasingly connected with algebra and analysis. Analytic geometry, developed by Descartes and Fermat, represents geometric objects through coordinates and equations—for example, a circle can be written as $(x-h)^2+(y-k)^2=r^2$. The 19th century produced an even more profound transformation with non-Euclidean geometry, differential geometry, projective geometry, and the study of curvature. Gauss's work showed that some geometric properties can be understood intrinsically, without reference to the surrounding Euclidean space.
Modern geometry is therefore much broader than the geometry of school textbooks. It includes differential geometry, algebraic geometry, topology, computational geometry, discrete geometry, projective geometry, affine geometry, convex geometry, and geometric group theory. Geometry now provides essential mathematical tools for physics, architecture, computer graphics, biology, medicine, engineering, and other branches of mathematics. A striking example is general relativity, where spacetime is described using geometric ideas, while algebraic geometry has also played an important role in major number-theoretic results such as the proof of Fermat's Last Theorem.
  • Geometry studies space and form: shape, size, distance, position, angle, area, and volume.
  • Euclidean geometry is based on axioms and logical deduction.
  • The Pythagorean theorem is expressed as $a^2+b^2=c^2$.
  • Analytic geometry connects geometry with algebra through coordinates and equations.
  • A circle can be represented by $(x-h)^2+(y-k)^2=r^2$.
  • Non-Euclidean geometry demonstrates that geometries different from Euclidean geometry can be mathematically consistent.
  • Differential geometry studies curves, surfaces, curvature, and higher-dimensional spaces.
  • Topology focuses on properties that remain unchanged under continuous deformation.
  • Algebraic geometry connects geometric objects with algebraic equations.
  • Computational and discrete geometry are important in computer science, algorithms, graphics, and optimization.
  • Geometry has applications ranging from architecture and art to physics, medicine, engineering, and mathematics itself.
  • The modern concept of a geometric space can extend far beyond ordinary three-dimensional physical space.
Source: Wikipedia — Geometry / PDF
