The Big Reset in Mathematics - Printable Version
+---- Forum: ARTICLES (https://mklab.gr/forumdisplay.php?fid=33)
+---- Thread: The Big Reset in Mathematics (/showthread.php?tid=2159)
The Big Reset in Mathematics - mklabgr - 09-25-2026
Daniel Spielman’s “The Big Reset in Mathematics” argues that mathematics is entering a period of unusually rapid change because AI systems are becoming capable of solving difficult mathematical problems, including problems that have resisted human mathematicians for years or decades. Spielman describes this as a “revolution” that could ultimately be positive for mathematics, but which will also disrupt careers, incentives and established research practices. He is particularly concerned about the flood of AI-generated purported solutions: many are poorly written or incorrect, and their sheer volume can make it harder for mathematicians to determine what is actually solved and to produce careful explanations.
A central argument is that mathematical credit will have to change. Historically, being first to publish a result provided a strong incentive and a relatively straightforward way of assigning credit. But if an LLM can produce a result from a short prompt, being the first person to obtain it may say little about the person's mathematical contribution. Spielman therefore suggests that journals, hiring committees and prize committees should increasingly value work where the human mathematician demonstrably contributed substantial understanding, judgment, problem selection, development and exposition. Simply asking an AI to solve a problem and passing the output to someone else should not, in his view, constitute authorship.
Spielman also discusses the implications for AI companies, publication and research funding. Rather than releasing enormous repositories of machine-generated solutions, he suggests that AI companies should identify important results and invite mathematicians to investigate, verify and explain them properly. He proposes an intentionally demanding publication test: researchers should publish work that they would be enthusiastic about explaining in many lectures. Grants may also become harder to design because openly describing a research problem could allow increasingly powerful AI systems to attack it before the researcher does; consequently, he anticipates changes in how mathematical research is funded and evaluated.
For students and mathematicians, Spielman’s advice is essentially to shift from merely solving existing problems toward choosing interesting problems and developing distinctive research agendas. He recommends using LLMs as tools while deliberately preserving periods of unaided mathematical thinking, because excessive dependence on AI may weaken one's ability to reason independently and generate ideas. His broader message is that mathematics may be moving toward a new equilibrium in which routine problem-solving becomes increasingly automated, while problem selection, conceptual understanding, exposition, creativity and intellectual direction become more important.
  • AI may fundamentally change mathematical research, not merely accelerate existing workflows.
  • The biggest immediate problem may be not AI solving mathematics, but the flood of unreliable AI-generated mathematics.
  • Correctness and exposition become more valuable when generating candidate solutions becomes cheap.
  • Being “first” may become less meaningful when thousands of researchers can ask similar AI systems the same question.
  • Mathematical credit may shift toward human intellectual contribution, understanding and judgment.
  • Simply prompting an AI and submitting its output should not automatically qualify someone for authorship.
  • AI companies could contribute more effectively by helping mathematicians verify and explain important machine-generated discoveries.
  • Researchers may increasingly need to choose their own distinctive problems, rather than competing to solve the same famous problems.
  • Grant systems and academic evaluation may need significant restructuring.
  • Students should study mathematics because they genuinely value the subject, rather than assuming that traditional academic career paths will remain unchanged.
  • Mathematicians should use AI but also deliberately practice mathematics without it.
  • The article's deepest point is that if AI makes solving problems cheap, then deciding which problems matter and understanding why their solutions matter may become the scarce mathematical skills.
Source:Daniel Spielman — “The Big Reset in Mathematics”
